I want to change my boundary line that i created by wall by face.
But i dont get the button to click on edit boundline (see print screen). The weird thing at 2 of my walls it is possible to do. And i made them al at the same time.There do is a button -> update to face. I try it out but no reaction.
Suggestions?
@Anonymous
If the face hosting the wall is not absolutely planar (warped) then you cannot edit the wall profile.
If the intention is to have a flat wall then fix the mass so that the surface is truly flat. On the other hand, if the non flat surface/wall is indeed desired, then use a void to cut the wall, or draw reference planes present the cut boundary and attach the wall to them.
