REVIT 2018 BIM DOCS is not showing on open dialog
benpowell6377
benpowell6377
When i open 2018 Revit and select open, then hit the Big Blue 'B' i only see my teams projects. i used to see BIM DOCS and BIM Teams directories.
Replies (7)
Alfredo_Medina
"Team" is kind of discontinued. Revit, starting from 2018.3 uses BIM 360 Doc (or any other versions of the name). You said you are using "Revit 2018", but what build number?
benpowell6377
i have all updates loaded.
Alfredo_Medina
@benpowell6377  That explains why you can't see BIM 360 Docs. Your version of 2018 is old. The latest build is 18.3.3.18
RDAOU
@benpowell6377
I am guessing that your next question is: where shall I download the update from.
If it is not showing on your subscription portal CHECK THE LINK HERE   below you can find a direct download link
http://up.autodesk.com/2018/RVT/9CA05B9A-1809-0510-A1B4-98696E090436/Autodesk_Revit_2018_3.exe
benpowell6377
we just needed the current 2018 thanks
Alfredo_Medina
@benpowell6377  , that is what I was saying since my first post.
benpowell6377
yes,
I was just confirming that your answer was what fixed it.
Thanks again
