Print to PDF text size too large.
When using "print to pdf" the text size in the PDF is being enlarged. In Revit it is fine and when printing a physical copy it is also fine. Only issue is the PDF which is what I need most of the time. Text everywhere is larger, even in the title block. Screenshots below. The first one is normal the second one is the PDF file.
https://ibb.co/Cb6bqYq
https://ibb.co/xY0YzyR
Do not check this box.
Checked this box.
