I'm having some graphic bugs with Revit 2018.3
It happens on all models and all of my computers : some have Nvidia Quadro and others are on Geforce
Windows,Revit and graphic drivers are all up to date.
Turning on or off the hardware acceleration doesn't change anything.
The main bug is when I try to move the windows ( properties,project browser,etc.) as shown in my video
https://photos.app.goo.gl/cIIk6Ornpujik8Bt2
Solved by ToanDN. Go to Solution.
Snail trail! Icky.
I'm just tagging on to follow thread. Haven't worked up the confidence to install 2018.3 yet.
I try to install updates hoping one day they will fix the graphic problem. But it never does.
Nvidia Quadro M620
Like every other user in here graphic drivers updates does not help at all. Messing with the settings as well does nothing. We need a update called 2018.4 that hopefully fix this issue in Windows 10
@javier.zavalawrote:We need a update called 2018.4
Ha! That's been my running joke the last several weeks. Every time I get up the courage to install 2018.3, I read another new issue posted.
Are you suggesting Revit 2018.3 is the cause, or are you just mentioning the version you are using?
I get this "snail trail" in Revit 2016 at work when moving properties. So, not entirely sure this is related to 2018.3 as such. Did this only start happening once you installed 2018.3? What happens if you reinstall Revit up to 2018.2?
It happens on all versions of Revit. I find it super useful to paint artwork on my screens with a Revit palette.
Seriously though, it isn't a big deal unless you spend more time moving palettes and less time drawing.
Sorry to hear that you are facing issues.
Do you have a multiple monitor setup?
Can you try the below for me and let me know if that helps resolve your issue?
In your Revit.ini change optimizedviewnavigation=0
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
I know it's not a big deal, but don't you think they should do something about it. We do pay a lot of money to use this program.
These comments always make me smile because they aren't really a demand for a fix but rather a plea for help with local issues.
This is most likely a local issue. Although you might be able to fix it by dumbing down the graphics in Revit, you might want to take a close look at the hardware network configurations. We have one user here that experiences this and he is pushing his graphics limits, using multiple monitors, a desktop, and a laptop in some sort of convoluted set-up. None of the other users here experience this.
As @RobDraw mentioned, please use this tool to find Certified and Recommended graphics hardware and drivers.
We would like to look at your journal files to investigate further, can you send us these files? I can send you a private upload folder.
Also, have you compared projects, does this happen with a particular project or on all files?
Viveka CD
Since you've tried disabling hardware acceleration and updated drivers, can you check your windows to see if there has been a fall creators update?
More information in this article: Revit: Windows 10x64 Fall creator update (build 1709) – Graphic problems when moving the properties ...
Let me know if the rollback helps resolve your issue.How to Use the Rollback Function in Windows 10 1709, 1703 and Earlier Versions of Windows 10
Looking forward to your reply update.
Viveka CD
I see what you are saying!
Please try the below solution for me, and let me know if that helps!
Solution:
Forum Thread: Revit 16,17,& 18 Crashes after Fall Creators Update (Windows 10 version 1709)
As mentioned earlier we can filter the cause of this from your journal.
Viveka CD
I have seen this in all versions of Revit until 2019, seems to be fixed
