Transfer host parameters & nested families to another family
2 ANTWORTEN 2
Nachricht 1 von 3
vicenteasensio
474 Aufrufe, 2 Antworten
Hello:
I have a projecr wich has 2 copies of a Funiture System family (called A & B).
I have 2 Funiture face-based families (Called 1 & 2) nested in "A".
Family A has nested on one of his faces the families 1 & 2
Family B has not nested 1 & 2
Is there a solution in order to copy the nested families 1 & 2 from A to B?
Dynamo?
2 ANTWORTEN 2
Nachricht 2 von 3
Ilic.Andrej
als Antwort auf: vicenteasensio
If you want 1 & 2 to be always the same when nested in A, B or any other system, all you have to do is make 1 & 2 shared. When working in project, you will be able to change the parameter values of those nested families and A and B will be automatically updated.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 3 von 3
Ilic.Andrej
Dynamo?
Why not just load them to B.... Or you can copy to clipboard and then paste it aligned to current view.
Andrej Ilić
MSc Arch
