revit 2016
revit 2016
Message 1 of 11
revit 2016
after making wall
section lines between walls and floor doesnot appear in 3d
Replies (10)
Message 2 of 11
ennujozlagam
@Anonymous hello, try to untick your 3d hardware acceleration and set your detail level to fine and see if helps. thanks
Message 3 of 11
i think the problem in revit
see the picture
Message 4 of 11
ennujozlagam
@Anonymous hello, don't mind follow my suggestion first? if doesn't work then we move to the next option. thanks
Message 5 of 11
ennujozlagam
@Anonymous hello, if not,  post your file here so we can check. thanks
Message 6 of 11
yeh it doesn't work
i told you after making your suggestion
Message 7 of 11
ennujozlagam
@Anonymous hello, okay, post some part of your file here to check. thanks
hello, this happen only to this file or other files too?
Message 8 of 11
i have many levels
i draw wall in zero level and make floor in the above level
Message 9 of 11
ennujozlagam
@Anonymous Hello, the reason is your wall blocking the floor that's why you don't see the lines or cut short your walls up to the finish floor. Thanks
Message 10 of 11
i dont understand
i need the floor under the all walls
Message 11 of 11
ennujozlagam
@Anonymous hello, then you need to cut short your wall to the finish floorif you want to sse the lines. thanks
