Message 1 of 11
10:37 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
@Anonymous hello, try to untick your 3d hardware acceleration and set your detail level to fine and see if helps. thanks
i think the problem in revit
see the picture
@Anonymous hello, don't mind follow my suggestion first? if doesn't work then we move to the next option. thanks
@Anonymous hello, if not, post your file here so we can check. thanks
yeh it doesn't work
i told you after making your suggestion
@Anonymous hello, okay, post some part of your file here to check. thanks
hello, this happen only to this file or other files too?
i have many levels
i draw wall in zero level and make floor in the above level
@Anonymous Hello, the reason is your wall blocking the floor that's why you don't see the lines or cut short your walls up to the finish floor. Thanks
i dont understand
i need the floor under the all walls
@Anonymous hello, then you need to cut short your wall to the finish floorif you want to sse the lines. thanks
