Revit 2016 Content Library
How do I install the Revit 2016 Content Library only? I am having troubles accessing templates in Revit 2016, so I followed the steps here: http://autode.sk/1F8XLvN and got as far as successfully uninstalling the content library.
sureshchotrani
You should never uninsallt the Revit content library, know you will have to install complete Revit software:(
look here what i did suggested
You will have to do the same after complete installation of Revit Software, first uninstall revit & then again install don't hit repair or reinstall that to will not work.
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
Tony_Michniewicz
There have been numerous posts about Revit content installation failures and a new post has been created to focus our troubleshooting efforts.  If you continue to encounter this problem, please refer to this post for the latest details on this issue.
Tony Michniewicz
Autodesk Revit QA
Tony Michniewicz
Revit Software QA Analyst
