fit image to element without material tile
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
arunag
4005 Aufrufe, 6 Antworten
Dear all, Can we fit the image given in material to the element , here eg may be a Floor.I am not able to do this though I remember doing it in earlier versions of Revit. I have attached the image I want to fit into the floor of size 3mx3m. I do not want to tile it, nor I want to use decal.floor.jpg
Aruna
School of Architecture
Ramaiah Institute of Technology
Bangalore
6 ANTWORTEN 6
Nachricht 2 von 7
sureshchotrani
als Antwort auf: arunag
Hit on the box shown below,
Adjust below
Hope it helps:)
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
Nachricht 3 von 7
arunag
als Antwort auf: sureshchotrani
I was looking into the same ..but my editor does not show UV options as you have captured. I am on 2015 revit. am I missing anything?
Aruna
Bangalore
Nachricht 4 von 7
sureshchotrani
Don't go from Manage tab.
Go from properties of object:)
Nachricht 5 von 7
sureshchotrani
Nachricht 6 von 7
arunag
Its the same. I guess the texture editor is changed but uses the same funtionality as I see in yours.
I did the tile none under repeat ,but did not see any material on the floor.So I have tile option on, but  it had tiled unequally into two parts. I figured out the offsets  from the edges by using the measure tool & adju2015-05-10_14-07-23.jpgsted the offsets to finally manage the image fit the floor.2015-05-10_14-02-02.jpg
Aruna
Bangalore
Nachricht 7 von 7
I really need some help. I tried high and low.
I just cannot get the image to fit in.
I am trying to apply the material to a cylinder.
