Revit 2015 Family Template File location
138 REPLIES 138
Message 1 of 139
bcampbell11
103291 Views, 138 Replies
Anybody know where the family template files are located now?   I have no template folders or "Libraries" Folder in the following location C:\Program Data\Autodesk\RVT 2015\.
I am not sure if I need to reinstall Revit or look in a different spot.
Thanks!
138 REPLIES 138
Message 121 of 139
in reply to: bcampbell11
bcampbell: i thik you should use the add/remove feature from the control panel, it will redownload those files but you have to stay connected to internet...
Message 122 of 139
in reply to: scott_d_davis
please davissc, I need to know the default size of either RAC 2015/ RVT2015 because my network is not stable if I am downloading (through the add/remove features). thnks
Message 123 of 139
hi
You First need to EXIT Autodesk Application Manager.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
Message 124 of 139
CADdaddy.com
Message 125 of 139
4t
Message 126 of 139
bahoznarin
Message 127 of 139
There have been numerous posts about Revit content installation failures and a new post has been created to focus our troubleshooting efforts.  If you continue to encounter this problem, please refer to this post for the latest details on this issue.
Tony Michniewicz
Autodesk Revit QA
Tony Michniewicz
Revit Software QA Analyst
Message 128 of 139
Sometimes is not a problem with libraries, in my case I have to uninstall autodesk revit 2015 , then i install it again and templates and families apear.
I have to say before do it, also reinstall libraries several times  and it don´t work.
Juan
Message 129 of 139
in reply to: Tony_Michniewicz
I have uninstalled and reinstlled and still when i come to load a family the metric library is empmty, same when I come create a new family...no templates!!
I also get this message when revit starts up. see attached image.
Message 130 of 139
You have to go to panel of control,in programs&characteristics try to
uninstall autodesk revit content.Then will appear a Revit panel,go to add
components, check "US metric,Generic international content and your mother
language(for me is spanish)" and then press next.,It will take a while,
when the process is finish you should have your templates and metrics
families.
Juan Mansilla from Chile
Message 131 of 139
Make sure that in your folder and search option the (show hidden files,folders) must be selected..
Its because some of files might not appear because these are hidden
Message 132 of 139
aun estoy aprendiendo a usar el programa y me estoy basandoen los templetes
Message 133 of 139
thomk
If you're getting the dialog box but it appears that the content is actually installed, I found the following solution on two machines:
http://forums.autodesk.com/t5/revit-architecture/revit-2016-family-template-file-location-not-found-...
Hopefully that may help someone else.
Thanks!
-Thom K.
Message 134 of 139
Hi Tony
We all are interested in downloading the content separately from the setup because this issue is frustrating me.
tnx
Message 135 of 139
how can i download
revit rac
Message 136 of 139
GHASEM_ARIYANI
hi
1- go to  Control Panel > All Control Panel Items > Programs and Features
2-Dubel Click on the Autodesk Revit Content Libarries 20XX .
3-click add or remove feature and select US Metric.
4-click Ok
Message 137 of 139
ilovemehedi1
You can check your programe date.
Path:C:\ProgramData\Autodesk\RVT 2015
It's located in programe data.Normally programe data hide default.You have to uncheck the hidden files.then you will get it.
And go with my given You will get the template.
I hope it's helpful for you.Thanks
Message 138 of 139
in reply to: klientemch
I am trying to add an .RFA (family) in Revit 2017.  When I try and add a family or say a toilet or other plumbing fixture, I get the following error:
"The file Toilet-Domestic-3D.rfa was saved in a later version of Revit and cannot be retrieved in this version"
How do I downgrade my RFA content libraries to Revit 2017?
Message 139 of 139
install the latest revit version
