Revisions Schedule
Revisions Schedule
designQACJB
Message 1 of 8
Revisions Schedule
designQACJB
Hi All,
I need help with the following:
Why even though that the dates are newer, if I put numeric for the last 2, they are sent to the beginning? I would like to organize the revision by date, or at least have the letter first and the number after.
Replies (7)
Message 2 of 8
Alfredo_Medina
Use the highlighted tools on this image, to do what you need:
Message 3 of 8
revitnation
In keeping with Alfredo’s solution (Revit Option), one can also use invisible characters. I have had several employers that desired no value for the first couple of issues, such as bid set, permit set, etc. In those situations, I find myself using the following “invisible” Unicode character for the first couple of values.
https://invisible-characters.com/061C-ARABIC-LETTER-MARK.html
Message 4 of 8
Sort by Sequence or by Date.
Message 5 of 8
designQACJB
Hi there,
Thanks for the reply, unfortunatly it doesnt work as I still cannot put the "numer revisions" AFTER the "letter revisions".
Any ideas how can I change that?
I want to have in the revision schedule, first the letter revision and after the number revisions.
Message 6 of 8
Manually Move Up or Move Down
Message 7 of 8
are you saying you want to sort revision table by date? If so, edit Titleblock and change the way the revisions are sorted (Sorting/Grouping Tab).
Message 8 of 8
designQACJB
Thank you!!!! You are the man 😄
