I'm taking over a model from another user, I don't know what they did to cause walls to be solid when I apply a phase override. I want my existing walls to show greyed out double line walls instead of solid grey.
The walls turn from a nice... to not so nice solid fill.
The walls do not have any solid patter assigned them.
Here are the phase settings I'm trying.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Oops here is the graphics override that also did not work.
I also tried just the halftone check box, walls are still solid.
Try removing the material
Looks like someone gave the Phase - Existing Material a solid fill Cut Pattern. Go to Materials and remove the Cut Pattern.
