Reveal hidden elements in multiple views at once
martins.logins2
martins.logins2
I ran into issue where we need to unhide elements in over 100 views. So far the only known way is to manually open each view and unhide hidden elements. Has anyone had similar issue and how did you solve it?
I am trying to find a way how to do it with all views at once so we don't have to manualy do it.
RSomppi
How are these elements hidden? By element, category, filter? If "By Element", then you will need to go view by view.
Unhiding hidden elements is only temporary so a better explanation is needed.
ennujozlagam
have you try to create view template, unhide those objects and apply to all views you need to unhide objects?
martins.logins2
They are manualy hidden by "Hide in View -> Elements''. So technically have to do it manually to unhide them. I was just wondering if there are plugin which can automatize this
RSomppi
This is the nightmare situation I warn people about when using "Hide by Element" and you've taken it to entirely new level.
Are you wanting to unhide everything? If so, the best approach would probably be to recreate the views and copy/past annotations to the new view.
