Remove Fill from Architectural Column Family
PhilvK
Advisor Advisor
PhilvK
I vaguely remember doing something to add fill pattern in an architectural column family and now can't figure what I did, or how to remove it. These columns sometimes appear with the fill when loaded into a project and sometimes not. The family is attached if someone has the time to take a quick look. Thank you!
vitorbortoncello
If you join a wall and an architectural column, and the wall has a coarse-scale fill pattern defined, the joined column assumes that pattern. Structural columns do not assume the walls fill pattern, even when joined.
To change the fill pattern:
Replace your column to a structural one.
or
Use one of the override options:
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-67D3D6DB-E78D-4711-B9C3-4D30F1C22205
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
PhilvK
Thank you, but my issue is that the shading appears in the column family which would be independent of the project's coarse-scale fill pattern. I would like to why it is there in the family.
vitorbortoncello
You mean this shade? it is a default material, just change the material
