Resolution problem !
4 REPLIES 4
mairh_tsek
464 Views, 4 Replies
Hello all,
When I print in pdf the texts are bigger than in the project. I read that it is a revolution issue, but what I need to check? In the image below are the dispay setting of my pc. Is it something that I need to check in Revit?
Thank you in advance!
4 REPLIES 4
in reply to: mairh_tsek
Your configurations look okay. What font are you using?
mairh_tsek
in reply to: ToanDN
@ToanDN  ,
Arial , thanks
mairh_tsek
in reply to: barthbradley
@barthbradley  ,
The answer was here :
Log out and log back in to Windows to apply the changes.
Thank you!
Forma Design Contest
