Report
4 REPLIES 4
245 Views, 4 Replies
Report
Please, how can I see the answer to report number 7028470CER_12? Thank you
4 REPLIES 4
LisaDrago
Hello @Anonymous.
Umm... what kind of report are you looking for?
is this from revit crashing?
that kind of report is sent to autodesk. unless a internet window opened up and showed a possible fix like a service pack, you won't be able to see the report.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
in reply to: LisaDrago
I tried to install a CDTrial Version of Revit Architecture 2011, but was an error and it ask me if Iwant to send a Report, then it gave me the report number 7028470CER_12. I neverhad received the solution. Thank you.
That is the file codes for Autodesk Support...once someone gets to it in their support list they will send an e-mail to the one you provided.
Was there an error message that caused the report?
RDAOU
@Anonymous
Thats the report reference from the CER you submitted after that an unexpected error. You had the chance to see what was sent when/after you actually sent the report. That being said; the report is now with Autodesk (not on your PC). Once a solution is found they will contact you as @Anonymous already informed you.
The process/workflow is clarified HERE _ CUSTOMER ERROR REPORT  You can see here what info was sent
Forma Design Contest
Technology Administrators
