Render remove
Render remove
rob_hart
Render remove
rob_hart
I have created a wall Type which is made up of the usual suspects plaster/Blockwork/insulation/Brickwork & Render. My Design requires that some areas of the render need to be removed to reveal brickwork behind. Currently, the render wraps perfectly into the door and window reveals. Which I would also like to happen, at the point where I would like to remove sections of the render. I have tried so far to edit the profile of the wall, which removes the entire wall. Are there any work arounds out there?
Create Parts from Wall and then hide the Wall Layers that you don't want to see in the Rendering View.
rob_hart
Thanks for response, I will look into that as a solution. I did find a solution/work around in the end after my post. I edited thr profile of the wall cutting out the exposed brick section, this kept the wrap of the render. Then I added the same wall without the render into the section I had created.
