BEAM JOIN
BEAM JOIN
seamea12
BEAM JOIN
seamea12
Would you be so kind to help me with my beam join. I model my structural beam in my existing walls and chain option don't work properly . Edit beam doesn't help too. There are no such a problem when I have no wallBEAM JOIN.JPG
Hard to understand your description and screenshots of the problem.  Why don't you post the RVT file here so we can take a look and see.
seamea12
I can not attach rvt file becouse it's to big.I attache some explanation on a screenshot.
So, this is the condition?
Try creating a Level for the Beams at the top of the Walls and then place your Beams on that Level.
seamea12
Thank you for your advivce it works on my separate example of walls but in my model it dosn't work still. I was drawing beam starting from core of the wall and it generates this problem. When I changed my starting point problem disappeared happily.
