Render remove
2 ANTWORTEN 2
Nachricht 1 von 3
rob_hart
231 Aufrufe, 2 Antworten
Render remove
I have created a wall Type which is made up of the usual suspects plaster/Blockwork/insulation/Brickwork & Render. My Design requires that some areas of the render need to be removed to reveal brickwork behind. Currently, the render wraps perfectly into the door and window reveals. Which I would also like to happen, at the point where I would like to remove sections of the render. I have tried so far to edit the profile of the wall, which removes the entire wall. Are there any work arounds out there?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: rob_hart
Create Parts from Wall and then hide the Wall Layers that you don't want to see in the Rendering View.
Nachricht 3 von 3
rob_hart
als Antwort auf: barthbradley
Thanks for response, I will look into that as a solution. I did find a solution/work around in the end after my post. I edited thr profile of the wall cutting out the exposed brick section, this kept the wrap of the render. Then I added the same wall without the render into the section I had created.
