Visibility problems lines in floor when export pdf
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
gestioa_aiertarkitektura
319 Aufrufe, 4 Antworten
Hi, i have a problem, when i export a pdf , there are some floor lines that dosnt have to be there, i dissabled all subcategories in floor, but it still there. someone knows how to fix  it o why it appears?
Beschriftungen (1)
4 ANTWORTEN 4
Nachricht 2 von 5
What kind of PDF reader are you using? It can be the rendering settings of the reader.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Nachricht 3 von 5
Hi, im using Adobe Acrobat, but its use to happen when i did floors with point of elevation, when i did simple floor without elevation, there are not that kind of lines
Nachricht 4 von 5
Yes, these are the folding lines of the floor when using the elevation points. When you turn them off in Revit, you will see the white lines in Acrobat Reader. To turn them off open the settings in Acrobat Reader (CTRL + K) and turn off the smooth lines settings. (page display tab)
Nachricht 5 von 5
thank you so much. it worked
