render on Lumion not separate material
mohiroal
mohiroal
Hi
I have finished the model on Revit and picked every material separately and exported it to Fbx but when I import it to Lumion find it is not separate @barthbradley @ToanDN
Use Lumion Livesync add-in to work seamlessly without FBX.
https://support.lumion.com/hc/en-us/articles/360007538494-Download-Lumion-LiveSync-for-Revit
And different Revit materials must use different Appearance Assets.  You Revit view is shaded so you need to set the view to realistic to be able to see if the materials are different or not.  If they appear the same then you need to edit the materials and change their appearance asset under Appearance tab.
