renaming levels
renaming levels
renaming levels
Hey.
I have removed (said that it should no longer appear) the dialog box that appears when you change the name of your levels, it asks if you want to make the change in general for levels or only for the individual level.
Is there anyone who can help where I can find and activate this box again?
thanks in advance
Jonas
_Vijay
Hi @Anonymous , if you rename the level it will ask you, only the level need to rename or the floor plans belongs to the level also need to rename. so choose as per you need. Hopes its helped you.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
martijn_pater
Tanks 🙂
it's back to normal again
