How to show Finishes on exterior walls?
4 ANTWORTEN 4
Nachricht 1 von 5
tstewart
1046 Aufrufe, 4 Antworten
How to show various Siding/Finishes (i.e., Clapboard, ACM, Stone, etc.) on exterior walls?
4 ANTWORTEN 4
Nachricht 2 von 5
martijn_pater
als Antwort auf: tstewart
You could use split face... or curtain wall...
Nachricht 3 von 5
mauricio_mssf
Firstly, these materials must be aplied to the location (wall, windows, etc.) where you want in the model, second you need to configure these materials to appear as a surface pattern (to see in the Hidden line visual style)
https://www.youtube.com/watch?v=jgsdfEidDQc
set their color and appearance if you want them to be seen in a consistent or realistic color.
https://www.youtube.com/watch?v=d3faRHHyDYU
But remembering, these materials must be applied to the model. in Revit you see what's in the model.
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and let a like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Nachricht 4 von 5
tstewart
als Antwort auf: martijn_pater
How to use a Split face detail?
Nachricht 5 von 5
Mohamed-Nassar
create it in your wall type by stacked wall or any type u need to use then check detail level is Fine to show the reveals and sweeps.
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
