HI, im currently running Revit and Autocad 2023 do i still need to need to have Autodesk advanced material libraires from 2020 and 2021 installed or is it okay to delete them.
Solved by syman2000. Go to Solution.
I removed all but the current ones months ago and haven't noticed any issues.
Autodesk shared Material is shared yearly based on which software you installed. If you still have an older version of Revit and remove the Autodesk shared material 2022 & 2021, any software from those years will be impacted. So if you want to remove material from 2020 & 2021, make sure other Autodesk software with that year is also uninstalled.
