remove time from date/time stamp in titleblock REVISITED
jledgewood409
Message 1 of 65
jledgewood409
I know this topic was brought up in the past. and I believe the solution worked for windows xp.
now that we are in windows 7 and above I would like to know how to remove the time portion from the "date/time stamp" that in the titleblock?
revit 2015
Accepted solutions (3)
Replies (64)
Message 61 of 65
VM_Jekabs
One solution I found was to create a label with a formula parameter, and for the formula input a couple of black square characters (█):
Then for the color choose 254-255-255. This will act as a masking region that effectively masks the time.
Message 62 of 65
00353629
It worked as you said but the date is wrong in my case. today is 01/13/2025 and when i apply the formula i becomes 01/10/2025. Even if i save the document and the family it doesn't update.
Message 63 of 65
eramoy
I think this "solution" just applies the Sheet Issue Date parameter, which isn't automatically updated.
Message 64 of 65
jrobbins
I followed these steps to the letter and I'm getting the ORIGINATION date of the sheet, not the current date.
Message 65 of 65
ChristopherIKVU6L
Incredible, finding this in late 2025. Thank you.
