Remove line from joined geometry (CONCRETE)
nadifa.aulia
Message 1 of 8
nadifa.aulia
Hi, could you see the lines on the column surface? I created a column and added a corbel. I already joined these two elements, but the line still won't go. does anyone have a solution for this?
Replies (7)
Message 2 of 8
ennujozlagam
the only way to remove that line is to create a column family and use join geometry?
Message 3 of 8
syman2000
Try align the top of the coble surface with the top of the L column. If that won't work, your other option is to add the coble into the L column family and do a join geometry there.
Message 4 of 8
nadifa.aulia
could you tell me how to create your column? I already create L column and add corbel then JOIN them but nothing happened
Message 5 of 8
ennujozlagam
1st step
2nd step
3rd step
change dimension to suit your needs
Message 6 of 8
Are you sure the top faces aligned?
Message 7 of 8
handjonathan
Hi @nadifa.aulia
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @barthbradley @ennujozlagam @syman2000  helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
Message 8 of 8
nadifa.aulia
How to make sure it alligned? i created the corbel by attaching it to the surface of it column
