- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello, I have made a curtain wall panel family - repeating circle pattern. The pattern works great but is there any way to remove/hide the gridlines that are between each panel. The family is a 6" x 6" module and after applying to a curtain wall, that is a lot of grid lines. The only method that has worked is picking each panel and changing linework to invisible line. I thought maybe there is a dynamo script or something similar that could make the process less tedious.
Christian
Link copied
