Remove Beams from Floor Plan
cadedu22
Message 1 of 8
cadedu22
Aye,
How can I remove from Architectural "Floor Plan" structural beams?
When I'm configurations plan views they sometime appears.
Replies (7)
Message 2 of 8
RDAOU
@cadedu22
Set underlay to NONE
Message 3 of 8
cadedu22
But overall is there a way to remove such beams form view?
Message 4 of 8
RDAOU
@cadedu22
what do you mean overall?! In yours those halftones are underlay so you simply set the underlay to none
  • The two elements in the bottom right corner are walls...not beams so I guess they are not relater to the original question.
To switch off beams in general you can toggle the Structural Framing Category in Visibility graphics
  • Alternatively view filters can be used
Message 5 of 8
cadedu22
No every thing is fine now, I was confused why structural elements showed up in floor plan.
I figured it out.
Message 6 of 8
David_Knight
VG ->Uncheck Structural Framing visibility
Message 7 of 8
I figured it out.
You mean structural elements above showed in floor plan as per your screenshot?  If so, then yes it's Underlay setting as suggested.
In general, I would not turn off major Structural categories (beams, columns) in Architectural views.  If they are under a floor/slab then they will not show unless you set the view to wireframe or set the floor to transparent.  If they are exposed then they should show or you drawing is misleading.
Message 8 of 8
cadedu22
@David_Knight
Yup, as RDAOU mentioned it, possibility to turn off
@ToanDN
Sadly they are inside or below construction, and they started to showing out when i was configurating "Underlay" settings.
I inserted structural "beams" inside floors / walls.
