Regions with transparent background?
fortywebs
fortywebs
Hi, I am trying to hatch over the house next door so that it looks a bit greyed out on the planning application, but when I do so, the hatch background is white rather than opaque, so it blocks out all the detail of the house, which I still want to see. I would also like to change the spacing of the lines and possibly change the lines to grey, and maybe have a slight grey on the transparent background, but still be able to see the windows and door etc. Please see my images. The first image shows the region highlighted - when highlighted it is transparent, but when I click off it (2nd image) it goes opaque. Where are the settings for the regions please?   Thanks
Accepted solutions (4)
Filled regions have a Type Parameter for Masking.
Try this:
Sahay_R
Which version of Revit are you in?
This is what worked for me in 2020. The second screenshot is the final result.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
fortywebs
Thanks, I didn't know about that masking button! yes that works, but I can't get the grey background to work like you have - I changed my background to magenta but its completely transparent:
How do I edit the
fortywebs
Background Fill pattern > Solid fill!!
You need a Fill.  Use Solid for the Magenta.
