The Reflected Ceiling Plan (Basement Level) is not showing the correct spot elevations, so how to make the elevations correct (-18.5'below grade)?
Spot Elevations have to be based off a location. Mine usually align to the same Elevation Base as my Levels.
Choose Relative spot elevation type and select Basement level for elevation base on the option bar of the spot elevation instance.
@tstewart wrote:
Spot elevations on RCP's are to locate ceiling changes (i.e., Soffits, Fascia modifications, sculpting elements, etc.), so it is very common to have Spot Elevations on RCP's.
I wasn't questioning the use of Spot Elevations in RCP. I was curious what you were tagging in RCP that was 18' 6" below Grade.
