Hello guys ,
I am trying to export spot coordination's within a dxf or dwg file, and all I am seeing in my export file is text and not an actual point. I would be glad even on how to create a csv file and i also tried that but am only getting a 7 digit number which doesn't make no sense to me, but no getting a northing or easting number.
Thank you in advance
Solved by constantin.stroescu. Go to Solution.
in fact Spot Coordinate is a tag not a point ... you have to export the Point (coordinates)
I think a way , could be by using a Generic Model -Adaptive Point placed on desired locations and then , by using Dynamo , collect these points and export them as .csv...
https://www.youtube.com/watch?v=kwDMqyB2ay8
Constantin Stroescu
When I am in Export mode , then why is it asking me how i want my coordination's exported?
Is there no workaround by editing the tag parameter's and adding a point just like you did so it adds automatically?
