Rebar Dimension
1 REPLY 1
ArmanMargaryan
107 Views, 1 Reply
Rebar Dimension
Hi everyone!
Is it possible to calculate the length parameter of the rebars not from the outside but from the inside?
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Linkedin | Facebook
Revit Structure Certified Professional
1 REPLY 1
What about changing the cover dims?  Or are just wanting Revit to report it differently. I'm pretty sure that's not possible.  If this is for scheduling, you could get there via Calculated Parameter though.
Forma Design Contest
Technology Administrators
