Railing structure (Non-Continuous) is not extending to floor returning top rail and leaving a gap in between the structure, causing 2 elements to float in air. Is there a solution for this.
Thank You
Solved by BDMackey. Go to Solution.
Yes unfortunately this is how the railings work. By default you have to have an extension for the Top Rail to extend to the ground, unfortunately the rail profiles won't match that extension. You have to edit the path of the Top Rail, Remove the extension and then finish the path. Sucks that it is manual for all the rails.
Since you only have two rails below, the other option is to use Handrail 1 and Handrail 2 and add an extension to match the top.
