Really stange pdf print behavior Revit and Adobe PDF Pro
Message 1 of 8
I am really going crazy over a weird printing problem in revit.
I want to print in PDF with Adobe PDF pro.
Until now I never had any issues.
Today every pages I print all the documents on the board in multiple times like a mosaic background. It's really stange.
I put a pdf file to explain.
Does anyone know how to fiw this ?
Thanks.
Replies (7)
Message 2 of 8
nicholas_seibert
That is strange!
Is this happening on all projects?  What version of Revit? Has anything changed recently(updates to anything)?  Multi or single page pdfs?
Thanks!
Nicholas Seibert
Principal Revit QA
Message 3 of 8
Have you tried to restart the computer?
Message 4 of 8
Yes I have  tried that.
Nothing changes.
Message 5 of 8
It happens on every files now.
Nothing changed recently, no uptades or anything.
it juste happened over night.
thank you for your help
Message 6 of 8
Hello, So to inform you,
i tried to print on paper without going through pdf and it does the same exactly !
So indeed it must not be a pdf print problem but a revit problem.
I tried also to change the pdf printer, did it with pdf creator but same result.
So now I know it’s coming from revit.
What choices do I have other that uninstall revit ?
I have the 2019 version that I downloaded a month ago.
Thank you you so much if you have a solution.
Message 7 of 8
nicholas_seibert
Before you uninstall Revit, is this the only computer that is having the issue?
Nicholas Seibert
Principal Revit QA
Message 8 of 8
Hello Nicholas,
Yes it is the only one.
I’be investigated further and already uninstalled, installed back revit. Same issue but now I searched and there is some improuvment.
Now I can print plans without issues.
But elevations, sections and plans with texture will print the same way.
For some projects I can print the plan with texture if it’s not in the shaded display. But elevations and sections keep printing in mosaic.
In one project in particular everything print in mosaic.
So now I assume it’s because of the Raster print but I cannot find any answer anywhere.
Thats where I’m at right now.
Thank you for taking the time to answer.
