Add editable text label to Room Tag
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
lwindsor
5171 Aufrufe, 10 Antworten
I would like to add a label to my room tag that would allow me to click on it once installed in the project and edit the text.
Sometimes when designing homes, I like to give the client a floor plan showing Length x Width under the Room Name.  This would be easier if could make this part of the Room Tag rather than placing a separate piece of text in each room and trying to line it up under the room name.
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: lwindsor
Why not put the "Comment" parameter field label into the Room Tag?
Nachricht 3 von 11
If you want to manually type in the L x W value, add a shared parameter to the tag family as a label and to the project > Rooms category.
However, there is a way to pull the value directly from rectangle rooms. I can dig up the topic and post it later for you.
https://forums.autodesk.com/t5/revit-architecture-forum/room-tag-width-x-depth-parameters-generating...
Nachricht 4 von 11
als Antwort auf: ToanDN
Nachricht 5 von 11
lwindsor
als Antwort auf: barthbradley
Thanks to Barthbradley and ToanDN for your quick responses.
The Dynamo solution seems to be the most complete solution.  This is my first time using Dynamo and I am feeling a little out of place with it.  The problem I have may be with my Length and Width shared parameters though.  When I select the room, the Length and Width are now part of the room parameters, but display no values.  Is this a parameter issue, or is this a Dynamo issue?
Nachricht 6 von 11
lwindsor
Attached below are a screenshot from Revit and a screenshot from Dynamo.
Nachricht 7 von 11
I didn't have a chance to study the Dynamo approach but if it is in the Knowledge database then it should work.  Anyhow, if the Rooms are rectangle, using the OOTB method with formulas in a Room tag does work.
Nachricht 8 von 11
lwindsor
Thanks to everyone for all of your replies and assistance.  I have come up with a room tag using a similar formula to the one suggested by ToanDN.  The only problem is that it doesn't work with a non-rectangular shaped room (of course).  My solution for that was to include an option to fill in the dimension manually.  There is also an option to display only the room name for dimensional floor plans.
I am attaching the room tag file I created if anyone wants to use it.
Thanks again for everyone's help.  Have a Great Day!!!
Nachricht 9 von 11
deanguggenheim
Hi thank you for your contribution. I was wondering how do you edit it manually because when I tried that, a question mark appears instead
Nachricht 10 von 11
lwindsor
Hi Dean:
Just double click the question mark and it should allow you to edit it there on the screen.
Thanks and have a great day!!
Nachricht 11 von 11
Y_Dave
I CANT EDIT THE MANUAL TEXT , ALTHOUGH THANKS FOR RECREATING IT
