Readjust Project coordinates
Hi
I am not able to adjust my project coordinates. I have done the project coordinates but later realized that it is incorrect and want to change and correct. Whenever I go to Manage>Coordinates>specify coordinates at point. I get to the specify coordinates dialog box but I am unable to change or edit the text of the latitude and longitude, only the elevation is editable. (See attachment)
Please help in anyway you can, What am I doing wrong.prject. coord Capture.JPG
Which element did you pick the point from?  Why not edit the coordinates of the Project Base Point?
pipapongo0909
HI,
If you want to stick with shared coordinates, do the following:
  • create new Revit project
  • setup the coordinates as you need them
  • link to your original project file
  • reaquire the coordinates
i hope this helps
Jeff Wurth
BIM Manager | Dipl Ing. Bauingenieur
LinkedIn
