Re-adjusting Project Co-Ordinates
Good day
I am having trouble trying to figure out how to edit the co-ordinates of my project. I have done this in my project before but later realized that it is incorrect; I want to now change and correct this.
Whenever I go to Manage>Coordinates>Specify Coordinates at Point, I get to the specify Coordinates dialog box but the problem is that I cannot type into the latitude or longitude text, I can only edit elevation. (see attached image)
What am I doing wrong, how can I change this.
Any help will be appreciated.
Sahay_R
Go into VG / View Template, as the case may be.
Model Categories>>Site>>Project Base Point OR Survey Point
Each point will display the coordinates that have been input. You may click and edit the values.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
