How to Drop Some area of same slab
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
If you only drop the top of the slab then use a void to cut it, the dropped area will become thinner. If you need to maintain the thickness of the slab then create two different slabs with different elevations and join them.
im doing also the same thing (maintaining slab thickness ). but i want to make normal slab and drooped slab in one object. is that possible to do it ???
as line attached image.
bcoz i dnt know whats the proper way.
