Readjust Project coordinates
2 ANTWORTEN 2
Nachricht 1 von 3
250 Aufrufe, 2 Antworten
Hi
I am not able to adjust my project coordinates. I have done the project coordinates but later realized that it is incorrect and want to change and correct. Whenever I go to Manage>Coordinates>specify coordinates at point. I get to the specify coordinates dialog box but I am unable to change or edit the text of the latitude and longitude, only the elevation is editable. (See attachment)
Please help in anyway you can, What am I doing wrong.prject. coord Capture.JPG
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Which element did you pick the point from?  Why not edit the coordinates of the Project Base Point?
Nachricht 3 von 3
pipapongo0909
HI,
If you want to stick with shared coordinates, do the following:
  • create new Revit project
  • setup the coordinates as you need them
  • link to your original project file
  • reaquire the coordinates
i hope this helps
Jeff Wurth
BIM Manager | Dipl Ing. Bauingenieur
LinkedIn
