Re: Revit Hatches and Autocad
pendean
Community Legend Community Legend
pendean
Community Legend
Community Legend
@GCFEL The change has to be in REVIT, aka the source software creating the DWG file: since this is not the forum for REVIT, you'll have to ask over there for help using your software as you wish (if possible):
https://forums.autodesk.com/t5/revit-products-forums/ct-p/revit-products-en
GCFEL
I have Custom Hatch patterns specified within Revit and mapped, ready for Autocad.
Such mapped hatches when viewed within Autocad classed as a custom type, with the correct name, however do not reflect the correct pattern.
I have to select common patterns then exchange for the required hatch, which is ridiculous having already mapped them.
Any solution welcomed.
GCFEL
The assignment has been made within Revit and the file assigned similarly loaded into Autocad, however, it fails to convert successfully when observed within Autocad.
If no hatch conversions are applied, then the visual hatch integrity is achieved when observed within Autocad.
