RCP solid wall hatch not showing like Partition Plan
PETANJLGW
PETANJLGW
Hi, I have my existing walls showing as solid on my Partition Plan. I would like the existing walls to show solid on the RCP. What view template settings do I need to change? (thank you in advance)
Set the view's phase to New Construction and phase filter to Show Previous + New.
And View Templates are created by you so other people cannot tell you which one to use unless we have the model to look at.
PETANJLGW
Thank you for your reply. I found it in model overrides. 🙂
