Hi all,
I would like to know if there is a way to rapresent balausters and/or handrail as single line.
That is because sometime balausters in scale 1:100 (e.g. Diameter 30mm and distance from previous 130mm) see very bulky.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Constantin Stroescu
I think it is a problem with my first post...it doesn't work as I've expected to..
So I suggest to use the following method:
Constantin Stroescu
Wit Balausters you can because is a lodable family thus you can use Symbolic Line.
But hand rail are just 2D profile extrusion.
@XXalessio.amodioXX wrote:Hi all,
"Bulky"? Sounds like more of an issue with Line Weight of the Balusters. What's the Projection and Cut Line Weights?
I believe this is the best integrated solution instead of modifying families and handrails.
