Railing: Rapresentation
XXalessio.amodioXX
Message 1 of 9
XXalessio.amodioXX
Hi all,
I would like to know if there is a way to rapresent balausters and/or handrail as single line.
That is because sometime balausters in scale 1:100 (e.g. Diameter 30mm and distance from previous 130mm) see very bulky.
Replies (8)
Message 2 of 9
constantin.stroescu
  1. go to Object Styles and create a New Subcategory ( Modify Subcategories> New) for Railings - (I'v created Central Line subcategory)
  2. then in VGO uncheck everything but Central Line
Constantin Stroescu
Message 3 of 9
constantin.stroescu
I think  it is a problem with my first post...it doesn't work as I've expected to..
So I suggest to use the following method:
  • turn Railing in Edit Mode
  • in Edit mode, select the path (the magenta line) and Copy it to Clipboard
  • exit from Edit mode and Paste the Line into the Project - use the Wireframe Visual style to be able to see the line
  • in VGO uncheck all the Railing ...
Constantin Stroescu
Message 4 of 9
XXalessio.amodioXX
It might be a solution, but how you would do with balausters?
Message 5 of 9
XXalessio.amodioXX
Wit Balausters you can because is a lodable family thus you can use Symbolic Line.
But hand rail are just 2D profile extrusion.
Message 6 of 9
Shouldn't your top rail cover everything below it? Why would you see balusters?
Message 7 of 9
@XXalessio.amodioXX wrote:
Hi all,
"Bulky"? Sounds like more of an issue with Line Weight of the Balusters.  What's the Projection and Cut Line Weights?
Message 8 of 9
XXalessio.amodioXX
In elevation & sections
Message 9 of 9
XXalessio.amodioXX
I believe this is the best integrated solution instead of modifying families and handrails.
