Railing Post to Stair Stringer Mystery
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm baffled.
I have an Assembled Stair setup with steel channel stringers.
The stair hosts a railing set for the stringer position (not the tread).
The stair run is set for center.
The railing works great on the right-hand side (as you go up).
The Baluster/Posts stop on top of the Stringer channel flange and the cuts conform to the slope as intended.
BUT NOT on the left-hand side !?
See the attached images.
It doesn't matter if I mirror the good side to the opposite; or copy it to the other side and use the flip arrows; or even if I start over fresh with the same railing style and use the host to Stringer tool - it will not terminate the Baluster/Posts to the Stringer properly.
To save you from having to ask a lot of questions on the details, I have attached the Revit 2021 model of this, hoping you can all take a shot at it...
Let me know if you figure it out, and have a successful result.
