Railing issue - any solution?
taiorm01
taiorm01
Why is it possible to separate the railing at one staircase, but at the other, as marked, it is not possible to separate the railing? I have visualized the problem as best as possible. Is there a solution to the problem? Thanks in advance.
The path of a railing when sketch must be continuous but you can split the railing to multiple segments using Split tool.
ridantuo
Split Elements - Delete Inner Segment is good for it as you want a gap.
PICNIC: Problem In Chair Not In Computer.
Around 90% of issues can be explained by human error instead of an actual error.
