Why is it possible to separate the railing at one staircase, but at the other, as marked, it is not possible to separate the railing? I have visualized the problem as best as possible. Is there a solution to the problem? Thanks in advance.
Solved by ridantuo. Go to Solution.
Solved by ToanDN. Go to Solution.
The path of a railing when sketch must be continuous but you can split the railing to multiple segments using Split tool.
Split Elements - Delete Inner Segment is good for it as you want a gap.
