Floor pattern on angle
2 REPLIES 2
TeresaXMJLQ
255 Views, 2 Replies
Is there a way to change the floor pattern to align with the walls that are angled on the plan?
Question 2: Is it possible to align the tile to the wall as you can in ceiling grids, so there is not a 2" gap? (see floor jpg)
Thanks~
2 REPLIES 2
Hi @TeresaXMJLQ,
I assume you have used a model pattern for the floor material?
If so just use align and tab select one of the lines of the pattern to align it to a element.
Or Tabselect a line of the pattern and use the rotate or move command to change it's angle or position.
- Michel
TeresaXMJLQ
in reply to: TeresaXMJLQ
No they had used drafting, not sure why, but this makes sense now though. Much better, Thanks!
