Railing embedded in wall
tstewart
Message 1 of 8
tstewart
How to embed a railing, or make it in front of a wall that is (3) stories?
Accepted solutions (3)
Replies (7)
Message 2 of 8
Why can't you sketch it in front of the Wall?
...or are you saying you want a 3-story tall balusters?
...Maybe doing the Railing as a Curtain Wall/Panel would be better.  Can you post an Elevation View of Railing?
Message 3 of 8
tstewart
The wall is a 3-story element, so the railing is on the 1st floor.
Message 4 of 8
tstewart
The railing needs to be in front of the wall. whenever the wall is cut, it disappears on all floor levels.
Message 5 of 8
Lachlan-JWP
hat are you trying to make? Is it a railing for a balcony? If so it might be best to use a railing family, that way it hosts to a level, not to a wall that you are cutting away.
Message 6 of 8
bin
Maybe you can model it anywhere and pick new then pick the floor on that level.
Message 7 of 8
I'm terribly confused. "Railing embedded in wall"???  Are you maybe trying  to figure out how to create an opening in the Wall for the railing  -- or is the railing fastened to the exterior of Wall as a decorative element (e.g. no Wall opening)?
Message 8 of 8
tstewart
I'm trying to show railings on multiple floors, while not cutting the lower walls. I think that I have solved it.
