Hi I can't remove the 'Top rail'.
When I uncheck the 'Top Rail' box I get the following error. Please see attached.
All Balustrades appear won't appear unless the 'Top Rail Element' is selected?
Solved by RDAOU. Go to Solution.
You do not remove it... Instead you delete it
