"The License manager is not functioning or is improperly installed" REVIT 2020.1
sohaib.baheth
sohaib.baheth
222.JPGSo .. as you can see this is what is happening after the last update that I've installed then restarted the computer .... i fed up of autodesk troubles! i haven't been able to do anything normally for 2 months!!!
This is a Users Forum. You may want to give Autodesk a piece of your mind directly. Open a support case through your Autodesk Account UI.  They are usually pretty good in responding within 2 days.  Good Luck.
RobDraw
Alternatively, you ask a question.
The Licensing and Installation forum would be a good place for a question.
Rob
